Coil Pack Clips
Lee P
 Share
We stock the Toyota coil pack clips but they are not always suitable as the stock wires can get very brittle and pins can break
We can now offer the coil pack clips with wires so they can be soldered to your loom and remove the broken ends.
We have been using these for a long time now and they fit much better onto the coil.
£6.60 each + del
Edited by Lee P (see edit history)
  • 1 month later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
can the plugs be dismantled and fitted directly to the stock pins, as my wires/pins are ok its just the plastic outer casing that is starting to fall apart.
No, you can't use the stock pins
If your pins are ok you can use the Toyota plugs which we also have in stock but they are a bit more money
What you need to be looking at though is the wires as they go very brittle and the casing cracks causing a short.
  • 9 months later...
  • 1 year later...
 Share
