SRD 170amp Alternators
Lee P
 Share
With all the extra electronics we are putting in the cars (audio, fans, twin pumps ect) its a good idea to uprate the alternator to cope
Also with the original units now 15+ years old they are getting old and tired
We now offer an uprated unit, these are brand new uprated alternators made for us by Mechman in the USA.
Spec is:
170 amp High Output S series alternator
twin rectifier plates
12 huge heavy duty diodes
hairpin stator construction for un-matched low RPM output and durability.
Installation is a direct bolt in, the stock belt can be used, and the unit accepts the factory Toyota alternator harness. In high current draw applications we recommend upgraded cabling.
170 amp £320 (£390 polished)
Prices are plus £15 delivery to mainland UK
Edited by Lee P (see edit history)
Hi Lee- when would you recommend somebody opting for the 200amp instead of the 160amp?
All depends on how much equipment you are running really.
If you have alot of stuff turned on at the same time then it can add up to a lot.
You can roughly work it out by adding up the amperage of the equipment that you are likely to have on together.
Audio
Fans
Lights
Fuel pumps
Heaters
ect
  • 3 weeks later...
  • 4 months later...
  • 3 years later...
  • 1 month later...
  • 1 year later...
 Share
