Busters NA-T build with Some TT bit
buster
 Share
hello as some of you may know who are also on mkivsupra.net I have been doing a NA-T build for quite some time.
I thought it would be nice to run a thread on this lovely forum as well.
In the past few months this build has had its ups and downs Biggest been when Alan Jeffries blow my engine in a mapping session, a few weeks back. since then I have pulled apart my spare engine to bare block and replacing and uprating all seals and bearings to have almost a new engine.
I would like to thanks Mark dance for a lot of knowledge that has helped me throughout this build ; :D.
below are the specs I got or are going for ENJOY!
I'm going for between 500-600bhp have to see what it dyno on the day.
My specs/parts...
Engine....
New Mahle pro series pistons
New BC pro rods
ARP head studs
ARP main studs
ARP conrod bolts
Clevite big end bearings
Clevite main bearings
Clevite trust washers
Toyota front and rear crank seals
Toyota oil pump seals
Toyota TT headgasket
Toyota cam belt
Toyota cam belt tensioner
Toyota cam cover seals
Toyota cam cover washer seals
Toyota cam shaft seals
Toyota aux belt
Teflon stem seals
Water pump
Toyota oil pump
ATI/Titan crank pulley
whifbitz aux tensioner pulley
Billet water pump pulley cover
Magnecor 8mm ht leads
2 inlet catch can
Polished aux pulleys
Trd oil cap
1jz aftermarket ffim with N/A runner (pulley has put his mad skills to work)
Fueling....
Billet fuel rail sard
Fuel pressure regulator
Bradded fuel lines
Willbro 255l fuel pump
Semans injectors 650cc
Electronics....
AEM EMS V2 supra N/A model 30-6101
Aem IAT sensor
Aem 3.5 map sensor
Aem air/fuel gauge
Aem wideband o2 sensor
Aem egt gauge
Aem egt sensor
depo boost gauge with volt meter oil temp and oil press
blitz dual boost control
Cooling....
alloy rad
Oil sandwich plate
Twin electric fan kit
16row oil cooler and braided hoses
Drive gear....
R154 gearbox
R154 act 6 puck 630ftb rated clutch
brand new R154 flywheel
brand new R154 slave
R154 front of prop shaft
chaser speedo sensor
modified shifter housing
R154 gearbox mount
LSD
Turbo....
Turbonetics T66 Turbo T4 Flange
4" Turbo inlet pipe
Turbo blanket
60mm wastegate hks rep
2jz GE manifold with t4 flange
HKS ssqv bov
all custom fmic pipes work 3"
fmic 3"
4" k&n cone air filter
Bradded Turbo oil lines
Single turbo down pipe
Second decat pipe
3" v band clamp for down pipe
screamer pipe
TT supra parts....
TT cam covers with 10an breather fittings sprayed same colour as car
TT Black spark plug cover
TT idle control valve
TT throttle position sensor
TT throttle cable
Everything else....
Stainless steel bolt set for various engine bits
Opieoils engine, diff, gearbox oil, and filters
Stainless steel fmic cover plate
Cnc machined rad brackets
So here is where the story starts.
I had a silver N/A manual I bought back in 2007 I was slowly modifying with no real plans to turbo.
when on the evening of the 24/01/2009 I aquaplaned on a very large puddle on my way home and lost control and hit a small wall and woke up on the other side of the road to this...
as you can imagine I was heartbroken been my first proper sports car at 21 years old.
so I got it home and broke it for parts making some money back, After this supra I new I would get a replacement just didn't know when, Been as I had saved and borrowed money fot the first. I passed my bike test went through a few bikes, bought a mr2 cheap fixed it up took it to a few supra meets with the local sw group.
Then I spotted a range rover orange supra with some light damage on mkivsupra forum.
This beauty
As I said there was some light damage but I came to a price with the owner and on the trailer it went back to my yard
Just after we unloaded it.
That same day I started work on stripping the front end to see the extent of the damage very minor.
From memory: hub, light, front frame, power steering pipe, wing, bumper, and washer bottle
Replacement wing, headlight, front frame
With the new front bumper almost looking complete again.
Next step was to have it sprayed here it is in primer
Finished fresh paint always looks the best
the car stayed is that for the summer I got it to a few shows and few supra meets
imagek
Edited by buster (see edit history)
  • Replies 257
As winter was on its was I got the thought in my head of doing a NA-T project. It was only going to be small and simple very basic setup 400bhp max.
So I started collecting bits as the pile mounted I found A donor engine to build parts on as wanted to keep car on the road for a little longer.
This is the finished engine ready to be put in the car
The car went up to my friends work shop (lots of space and a pit ;D )
and here it is just before we started work
Engine in and piped up
Then to cut a long story short I got an offer of a R154 gearbox with all parts apart from shifter extension for a good price.
this is the R154 next to my W58 box before we done the shifter
here is the shifter mod work of art
The boxes lined up with shifter mod complete Just before fitting
So after fitting The R154 box this looked like a build that could start to hold some good power. Now I wanted to spend some money on making it look right and uprating some parts, To improve performance. The first thing to do was to get rid of that nasty N/A inlet plenum and throttle body, That got replaced with a stock TT inlet (no easy job) using weld to build up round the ports so I could grind out the inside to meet the N/A runners. then using the TT ICV & TPS to keep everything working well.
here is the TT plenum with the weld built up
and here is it meeting with the runners
Soon as the traction control butterfly would not be in use I decided to remove it and flush the holes off
All finished in gloss black
So with the TT inlet I could now run a aftermarket fmic with TT piping so i bought just that 2-3/4" of turbo to intercooler and 3" to inlet.
We also clocked the turbo round a few degrees so the inlet pipe would miss the dizzy cap.
here is the stages
Once all was back running it got a full service oils and filters a final check and off for mapping.
This is where the story ends for the first engine as the mapper popped the engine half way through the session!
I have some dyno sheets right before it went bang
and now I am building a new engine with the specs you see at the top of the page pics to follow as and when the work gets done.
Where did you get your wastegate from mate? Is it a 4 bolt style one or are you using an adapter to allow you to use a vband clamp style one? I'm searching for a four bolt to fit mine and can only find the 50mm HKS style item at the moment.
He's got a HKS 60 mm v band wastegate (same as me)
As pulley said bud I made a plate up to bolt to the manifold and weld my v band too
Well I here the tt pump is good for 450-500 not sure howtruethat is. Secondly have ou built your fic pipe work for the na ? Now looking build though makes me eager to get mine going for the summer. Actually my want for power was increased when some twonk in a paxo overtook me the other day and my little crz didnt have a chance,......grrrr
NA automatic?
Cheers for the info, I think I'll have to see if anyone at works is half decent with a welder. I've had no luck finding anything in a four bolt style so will probably look at doing the same as yourself and Pulley with a v band wastegate. :thumbs:
i'm confused you have listed TT and NA head gasket? I'd be careful at that power with the w58 i know someone who went through 3 w58's at 365bhp :)
Aslong as you keep the torque higher up the rev band, or just low
Making use of the A01B ratio diff and w58 lower ratio box helps this , just means you rev out at 158mph
Also depends on driving style and mechanical sympathy
 Share
