SRD 3.4L Stroker Kits
Lee P
 Share
I will soon be releasing 3.4L stroker kits. :)
Have tried to come up with a range that provides an affordable but quality kit.
The kits are custom made and the lead time is 8 -10 weeks. A deposit is required when ordering.
Stroker kit: £4299 Rated to Approx 1200hp max(Billet Main caps or brace kit Required for 800hp+)
EN40B Billet Steel Crankshaft
BC Pro series Rods 625+ (Carrillo rods can be added for an extra £500.00)
Mahle 87mm Forged pistons
An oil pump drive gear will also be required for the crank on each kit, these are approx £180. You can remove the one from your stock crank but there is always the risk of damaging it so its best to buy one. This also means your stock crank is complete and can be sold on.
All kits come with 8.5:1 pistons but these can be changed if required at an additional cost, please contact me for details if you require a special CR.
Edited by Lee P (see edit history)
  • 2 weeks later...
Lee,
Will it be possible to just buy the crankshaft?
What I'm thinking is If you've already got a set of Carillo rods for the stock crank, will they work with the crankshaft?
That way it could be a reasonable upgrade path for those already with built motors. Plus I may be interested in one fairly soon depending on price ;)
Lee,
Hi Tony
I am just sorting the final specs now but the rods you have should work fine as they are the same spec, the pistons are different though so you would need them.
I can supply the kit without the rods no problem. :)
 Share
