Page 1 of 26 1234511 ... LastLast
Results 1 to 15 of 379
Thread: Wez Track Supra
  1. #1
    1.21 Gigawatts Club Member Wez's Avatar
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,732
    Feedback
    37 (100%)
    Cool Wez Track Supra
    Hey All,
    Thought I would start a thread for my track supra as its off the road at the moment while I get round to sorting various jobs out. Like most people I have an increasing list of jobs that need doing which I am slowly working through, as I complete them I will update this thread.
    Some jobs have been done already and will post up details later.
    This is how it looked before any work was started.
    #1 From SupraPod 2008
    #2 Engine bay needs some work
    #3 Still need to get the bodywork cleaned up
    #4 Engine bay after some work had been done
    #5 Getting there, BrandsHatch May 2011
    Supra: 1996 Silver, Syvecs S6 ECU, 500bhp & 500ft/lbs, 95ron Unleaded
    Porsche: 2002 Black 996TT, Syvecs S8 ECU, 630bhp
    Lexus: 2001 LS430, Toyota 3UZ-FE V8
    Odds: Dyno Plot | Turbos Compared | 2BarTuning | Engine Part Weights
    Steve Manley 01865 291300
    | Garage Clearout |
  2. #2
    quest for road supremacy Club Member paul mac's Avatar
    Join Date
    Aug 2002
    Location
    England - Lancashire
    Posts
    4,462
    Feedback
    23 (100%)
    subscribed
    93 JDM T61 510 hp
    my motor
  3. #3
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,732
    Feedback
    37 (100%)
    New Turbo Oil Return
    One of the 1st jobs to address was my turbo oil return, as the Induction Motorsport cast manifold kit was never previously installed on a right hand drive the oil return wasnt best placed as it rubs against the hard power steering lines.
    #1 This shows the old line rubbing on the power steering
    #2 Looks like I caught it just in time
    #3 Good job the IM kit uses a teflon oil return
    As the IM kit uses a teflon oil return line I wanted to replace it with another teflon line, this proved a nightmare as SpeedFlow and ThinkAuto were unable to supply teflon in -10. I ended up using an industrial supplier who could source the bits needed. To stop this happening again I looked at ways to improve the oil return adapter on the oil pan. Looking at other kits I decided it would be better to have a 45deg adapter onto a straight pipe, this would pull the line closer to the engine and away from the power steering lines.
    As you can see from this pic it sticks out way too far.
    I took the oil pan adapter to ThinkAuto and they managed to find a -10 45deg adapter that sort of worked. As you can see this has given me lots more clearance from the power steering, the only issue was it was a screw in adapter that didnt finish exactly where I wanted it.
    Once I had a position I was happy with I looked up a local welder who managed to do this for me
    | Garage Clearout |
  4. #4
    PS3 tag: Supra_Pig Club Member Pig's Avatar
    Join Date
    Aug 2005
    Location
    England - Essex
    Posts
    11,507
    Feedback
    8 (100%)
    Ohhhh, i love these threads. Subscribed.
    P.S - your supe looks like it has a white front in that pic
    UK Spec - 6 Speed - 66mm Single 650bhp
    1/4 mile: 11.8 @ 126.88 MPH - Suprapod
  5. #5
    Formerly TyranoSupraRex Club Member MarkR's Avatar
    Join Date
    Jul 2006
    Location
    England - Greater London
    Posts
    4,031
    Feedback
    21 (100%)
    Looking forward to seeing this. Good luck Wez
    1998 VVTI GT35R 6 speed - RIP 573bhp
    2006 911 (997.1) Carrera 4S with GT3 aerocup kit & forged 997.1 Turbo alloys
    2006 Mercedes B Class B200 turbo
  6. #6
    Posting is my life! Club Member Kev.O's Avatar
    Join Date
    Jan 2005
    Location
    England - Avon
    Posts
    5,000
    Feedback
    80 (100%)
    Looking forward to seeing this thread develop.
    95 UK T Manual Silver
  7. #7
    BOOSTED! Club Member JamieP's Avatar
    Join Date
    Jan 2006
    Location
    (Top Secret)
    Posts
    42,829
    Feedback
    172 (100%)
    Any cage pics mate?
  8. #8
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,732
    Feedback
    37 (100%)
    Next up was making the new teflon line, what I cant stress enough is make sure you have a decent hacksaw and plenty of tape otherwise you just end up mashing the line
    Here are the new adapters and olives, the plan was to use a 45deg adapter at the turbo end and then a straight adapter down to my new oil pan adapter.
    I did the straight end first, here is the olive installed.
    Next use some engine oil on the adapter and then push the hose all the way down using a twisting motion, it should look like this once done.
    Once both were completed I did a quick install and you can see there is no more rubbing
    | Garage Clearout |
  9. #9
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,732
    Feedback
    37 (100%)
    Quote Originally Posted by JamieP View Post
    Any cage pics mate?
    I have some unpainted ones, I will do a before and after when it gets painted which hopefully isnt too far away now
    | Garage Clearout |
  10. #10
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,732
    Feedback
    37 (100%)
    RedTop 25 Battery and Isolator Install
    I have changed from the large halfords battery to a RedTop 25 and also installed a battery isolator at the same time. I decided to leave the battery under the bonnet and ordered a suitable battery mount.
    With the stock battery tray out of the way I was also able to remove the remaining AC lines which are not required and then went about deciding how best to lay out the new battery and isolator.
    Once I was happy with the position I ordered some new battery lines from www.vehicle-wiring-products.eu which arrived a couple of days later and allowed me to crack on with the install.
    The isolator comes with two switches, one is an external kill switch and the other is a main power/reset switch for the cabin. Most race regs state that the external kill switch goes on the passenger side splash panel so thats where I mounted it.
    The isolator works by having a live circuit across the kill pins, the switch breaks the circuit and kills the power, instead of having this connected all the time I put a plug and socket inline which I can then stick a small bypass wire in to allow the car start.
    | Garage Clearout |
  11. #11
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,732
    Feedback
    37 (100%)
    Andy Robinson Roll Cage
    Here are some pics of the Andy Robinson roll cage, these were taken just after I picked the car up so it has no dash, I will post some more pics when its been painted
    This pic shows the harness bar being used, I no longer have the Recaros as I sold them to another member a while back
    | Garage Clearout |
  12. #12
    Me? Post? Never! Authorised Trader Lee P's Avatar
    Join Date
    Feb 2005
    Location
    England - West Sussex
    Posts
    4,328
    Feedback
    76 (100%)
    Looking good Wez
    SRD Tuning HKS Authorised Dealer
    Fastest Standing Mile Supra in the UK 198.55mph (825bhp & 627ftlbs at the Hubs)HKS GT2835 Twins11.8 @ 128mph 1/4mile SRD R35 GTR MY11 10.9 @ 123mph 1.59 60ft
    Built by me mapped by Ryan G of 2bartuning
  13. #13
    Hmmm.... Donuts Super Moderator Homer's Avatar
    Join Date
    Dec 2003
    Location
    England - Northamptonshire
    Posts
    26,718
    Feedback
    69 (100%)
    The block of wood is gone!! Only took 4 years
    moved to projects section
    Beer, the source of and solution to, all of lifes problems
    '98 RZ-S TT 5spd
    '94 GZ NA 5spd Aero
    '11 BMW 320D ED
    '93 RZ Boostlogic T67dbb 6spd (sold)
  14. #14
    Me? Post? Never! Club Member johnd-mkiv's Avatar
    Join Date
    Oct 2005
    Location
    England - Essex
    Posts
    3,333
    Feedback
    52 (100%)
    Good luck Wez
    750bhp single
    "You don't own a project car!! A project car owns you"
  15. #15
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,732
    Feedback
    37 (100%)
    Quote Originally Posted by Homer View Post
    Next on the list is the copper U bend to bypass the heater matrix
    | Garage Clearout |
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
