Page 1 of 8 12345 ... LastLast
Results 1 to 15 of 110
Thread: Time me think for my under the bonnet make over
  1. #1
    Gone Single now 500 BHP+ Club Member lui's Avatar
    Join Date
    Jun 2005
    Location
    England - Cambridgeshire
    Posts
    6,249
    Feedback
    18 (100%)
    Smile Time me think for my under the bonnet make over
    FROM THIS
    Shot with Canon DIGITAL IXUS 750 at 2007-07-09
    TO NOW THIS
    Couple of pic's of the state of pistons
    So now it's time for the major heart surgery to begin
    All started of by a approximately 5 months ago with symptoms of drastic oil loss every 400-500 miles kept losing oil kept going from max to min on dip stick.
    Slowly getting worse & in the end from 200-100 miles same loss on dip stick.
    At time loads of thing going through the mind turbo seals / valve stem seals who knows.
    Been slowly through this period picking up parts to do my next upgrade too.
    Next problem within the past month or 2 started getting bad miss fire.
    Next stage got it booked into Mark at Phoenix to do my next stage of upgrades & hopefully get misfire & oil problem sorted out at same time.
    Told Mark of oil & misfire problems. So before starting my Hybrid conversion mark wanted to do a couple of test to see what's happening inside the block. Cut long story short done leak down test & showed that No. 5 cylinder was only 50%.
    So before hybrid conversion starts off with Head to have look what's going on. On removal found that couple of valve guides badly damaged & looking at block there has been quiet a lot of detonation going on.
    To cut long story short while at this stage did no longer want my new hybrids going on with state of engine & head that it is.
    So now this is what i have gone for & deciding to do a complete make over to my engine bay.
    01. Brand new Toyota Short block
    02. Brand new oil pump
    03. Brand new water pump.
    04. New head bolts.
    05. Complete new engine gasket set.
    06. Head fully overhauled complete with new stem seals / guides where needed & fully re shimmed & what ever else need doing to the head to make it like brand new.
    07. Brand new Envy stage 3 Hybrids
    08. HKS 264 cam's for intake & exhaust
    09. Uk 550 injectors.
    10. Resistor pack.
    11. Aeromotive fuel pressure regulator kit with liquid filled gauge.
    12. E-Manage Ultimate & harnesses
    13. Aem air fuel ratio gauge
    14. Aem water temp gauge
    15. Carbon pillar pod for gauges
    16. Denso Iridiums IK24 plugs
    17. The new HFS-5 Water Injection System by Aquamist
    18. New o2 sensor
    19. New tensioner
    Some of my spec to compliment above:
    Blitz SBC I Colour Boost controller
    Blitz oil pressure sensor
    Blitz oil temp sensor
    Blitz BL Series EGT Gauge
    Blitz LM V Spec Front mounted Inter cooler with polished hard pipe kit
    Mikalor clamps for Inter cooler Hard pipes and all other places in place of jubilee clips
    Greddy chrome oil filter sandwich plate to take oil sensors
    New Apexi Power Intake filter
    Denso IK24 Iridium Spark plugs
    Blitz NUR Spec R Full stainless exhaust system
    Envy Performance Double DE-CAT 3” pipes
    1.2 Bar restrictor ring
    Walbro Up rated Fuel Pump
    HKS SSQV BOV / Dump valve
    Running on Fully Synthetic Oil (Silkoline Pro S)
    TRD (Jap spec) Oil filter
    All mechanical work carried out by Mark at Phoenix.
    All electrical work carried out by Matt Harwood.
    Mapping to be carried out by IanC.
    By tomorrow hopefully old engine fully out , picking up engine & major engine parts from Steve Manley Wednesday Morning.
    All ready for the weekend & hopefully all going back in & up & running by end of next week ready for JAE but no promises
    So end result brand new engine running on Envy Stage 3 Hybrids & hopefully right fuel set up for it too.
    See link below for complete web album / slideshow of my rebuild:
    http://picasaweb.google.co.uk/lui196...aEngineRebuild
  2. #2
    Join Date
    Jun 2005
    Location
    Posts
    6,249
    Feedback
    18 (100%)
    Question
    Quick question with the fuel set up will the Apexi Neo be fine for controling the fuel set up ?????????????
    Or should I be looking for somthing like a E-manage ???????
    See link below for specs of the Apexi Neo:
    http://www.apexi-usa.com/product_ele...=260&pageNum=1
    It's the newer version of the Apexi SAFC II
  3. #3
    12th Year of Suprology Club Member hogmaw's Avatar
    Join Date
    Mar 2004
    Location
    England - Oxfordshire
    Posts
    5,847
    Feedback
    2 (100%)
    What a state. Surpised it took you 5 months Lui with oil loss like that! You're in safe hands with Phoenix tho, and a nice project to get to grips with too, best of luck to you.
  4. #4
    Happy Club Member RobSheffield's Avatar
    Join Date
    Dec 2004
    Location
    England - South Yorkshire
    Posts
    25,958
    Feedback
    86 (100%)
    Good luck Lui, sounds nice spec
    Id prefer to use something like an E-manage rather than a Neo.
    My Garage
    Go placidly amid the noise and haste, and remember what peace there may be in silence. (Max Ehrmann - Desiderata)
  5. #5
    is always sideways.... Club Member Suprash's Avatar
    Join Date
    Aug 2002
    Location
    England - Hampshire
    Posts
    10,001
    Feedback
    9 (100%)
    Lui, I wonder if yours is the car that Mark phoned me about today, as my car was supposed to be booked in for tomorrow for some parts fitted, but as they havent arrived yet, he called asking if I would need my slot still as he was just about to strip a Supra completely.
    Also interesting to read about your oil usage, as I too use a lot of oil and mark originally thought oil rings, CW is adament (sp?) its valve stem seals........but interesting that you are getting a short block in , as thats what Mark suggested to me should my problems be oil rings......
    Team Yellow - Drag, Drift & Time Attack
    www.facebook.com/teamyellowdrift
    Maxxis British Drift Championship Pro Driver #55
    Sponsored by: Rockstar Energy Drink, 1:Eleven Customs, Supra Owners Forum, Knight-Racer, Austec Racing, SFS Performance Hoses, Stanced UK
  6. #6
    Hmmm.... Donuts Super Moderator Homer's Avatar
    Join Date
    Dec 2003
    Location
    England - Northamptonshire
    Posts
    26,716
    Feedback
    69 (100%)
    Crikey, what a mess! Looks like it's had some det issues in the past and some serious oil leakage. Not surprised after the last time we met, it sounded rough as hell
    As mentioned on the phone, I have some opinions as to the cause of these, but best we not discuss right now
    No5 is the piston most susceptible to heat issues so is normally the one that suffers det on an engine pushed past fuelling/cooling limits.
    Regarding the ECU, Ryan G knows the Apexi units very well so it would be worth a chat with him before making a decision which to go for. As I've mentioned before - choose your mapper - then choose your ECU
    Beer, the source of and solution to, all of lifes problems
    '98 RZ-S TT 5spd
    '94 GZ NA 5spd Aero
    '11 BMW 320D ED
    '93 RZ Boostlogic T67dbb 6spd (sold)
  7. #7
    Join Date
    Aug 2002
    Location
    England - Hampshire
    Posts
    10,001
    Feedback
    9 (100%)
    Quote Originally Posted by Homer View Post
    Fancy having a crack at mine then, as Im getting conflicting reasons from Phoenix and CW........
    PM us......
  8. #8
    Work... what work? Club Member
    Join Date
    Dec 2004
    Location
    (Top Secret)
    Posts
    382
    Feedback
    3 (100%)
    Best o luck lui, hope all goes well mate, i'll pop over and see you when my car comes back from michel lane.
  9. #9
    Join Date
    Jun 2005
    Location
    Posts
    6,249
    Feedback
    18 (100%)
    Quote Originally Posted by Suprash View Post
    Lui, I wonder if yours is the car that Mark phoned me about today, as my car was supposed to be booked in for tomorrow for some parts fitted, but as they ha vent arrived yet, he called asking if I would need my slot still as he was just about to strip a Supra completely.
    Also interesting to read about your oil usage, as I too use a lot of oil and mark originally thought oil rings, CW is adament (sp?) its valve stem seals........but interesting that you are getting a short block in , as that's what Mark suggested to me should my problems be oil rings......
    Well to cancel out all things i just wanted everything new & that way will cure all problems just did no want at this stage skipping anything & when all back & running still problems so at this stage just went for new everything
    When all work done hopefully will be like a brand new power transplant under the hood.
  10. #10
    PS3 tag: Supra_Pig Club Member Pig's Avatar
    Join Date
    Aug 2005
    Location
    England - Essex
    Posts
    11,507
    Feedback
    8 (100%)
    Unlucky lui - are you considering a forged engine for when/if you go single?
    UK Spec - 6 Speed - 66mm Single 650bhp
    1/4 mile: 11.8 @ 126.88 MPH - Suprapod
  11. #11
    GAZ - THE RIPPER!!! Club Member gaz1's Avatar
    Join Date
    Jan 2005
    Location
    England - Kent
    Posts
    11,372
    Feedback
    65 (100%)
    well done mate she will be worth it when she is finished
    BLACKIE HAS AN ANGEL
    t67dbb 615bhp@ 1.4
    he almost baits people to call him all the names under the sun and then he'll pull himself off while he hits the ban button
  12. #12
    Born Slippy Club Member mikeyb10supra's Avatar
    Join Date
    Jan 2005
    Location
    England - Essex
    Posts
    6,828
    Feedback
    11 (100%)
    Nice one Lui....for a moment I thoght you were going to do the work yourself and I was going to say hats off that will be an even nicer car once finished
  13. #13
    Subtle/Diplomatic Club Member Alex's Avatar
    Join Date
    Jun 2001
    Location
    England - Norfolk
    Posts
    15,803
    Feedback
    13 (100%)
    AFAIK the Neo still features the same range of adjustment in the fueling, and this isn't going to be as useful as an e-manage.
    The nice thing about an e-manage is that it's hidden out of the way so no dashboard clutter...
    Its your choice, you're not going too mad with the injectors so you'll probably get fair results with the NEO.....but I'd rather have the e-manage.
    - Alex
    2012 BMW S1000RR Black
    ex - 1996 TT Gunmetal Facelift Auto, ex - 1998 RSP TT6 VVT-i BL-T61, ex - 1993 MSB TT6 w/ MINES ECU / BBS LM's, ex - 1995 S13 200SX Facelift
    ______________________________________
  14. #14
    Join Date
    Jun 2001
    Location
    England - Norfolk
    Posts
    15,803
    Feedback
    13 (100%)
    Out of interest, something caused your det...
    Was the Apexi NEO already installed and "configured" by someone?
    I see you have an FSE Fuel Regulator. I'm delighted that you're replacing it with a proper FPR.
    I would suspect the NEO (incorrectly configured) or the FSE (prone to failure) are your most likely candidates for the cause. Unless the something else breaking up caused a hot spot (like the valve guide?)
    - Alex
  15. #15
    I'm part of the furniture Club Member Ian C's Avatar
    Join Date
    May 2001
    Location
    England - East Anglia
    Posts
    15,114
    Feedback
    13 (100%)
    A hot spot would only affect one cylinder I reckon. Nasty, nasty FSE gets my vote
    -Ian
    I love my job. It pays for my Supra.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
