Help with fitting HKS SLD 2
JohnHandy
 Share
Hi Guys,
Please help.
I have just purchased a HKS SLD 2 from http://www.motorsportworld.co.uk
The guy on the phone assured me that it was easy to fit and would come with instructions. :)
Oh yes it came with instructions alright (in Japanese!!!!!!!) :(
Is there an English version?
I have an aero top JZ80 2JZ GE auto.
All help gratefully accepted.
Thanks
  • 1 year later...
Yellow = Speed sensor wire to ECU
White = Speed sensor wire to loom
Black = Earth
Red = 12V Feed
ECU pin outs here
http://mkivsupra.net/vbb/showthread.php?t=35919
Sorry for the silly question, but, how do I know wich is the speed sensor wire?(I've looked at that ecu pin outs thread, but..I'm lost:D)
Also, sorry for the hijack, but if I fit a SLD, do I need to fit a FCD as well?(on a stock car)If so, wiring diagrams/infi anyone??
Cheers
Cheers
No problem mate i'd like to know too ;)
here is a ECU sheet that i started a couple of years ago that never finished but has most of the stuff you need, scroll down a bit till you see the 2nd ecu diagram and speed signal 1 is the one you want and its the pink wire,
Yupeeee!!!!Finally..:)Fair play 2 you, buddy!!!
So, The fitting process should b something like this? Please b leaniant(spelling?!:innocent:) as this would b my first time around the ECU:
1.Snip the pink wire from ECU
2.the yellow from the SLD conects to the pink comming from ECu
3.the white one to the pink heading for..wherever:D-speedometer?
4.The red one needs A live feed
5.The black -grounds
Anybody has a diagram with the same info for a FCD??
Cheers!!
 Share
